MP 0.26 and the Parent Folder
Jean_59
Post by Jean_59 »
1. In Browser mode, XnViewMP 0.26 crashes when I click on the Open (View) Icon after selecting the parent folder Icon (..).
(I understand trying to "view" the parent folder is a strange idea, but under the same circumstances, 1.97 doesn't crash, but just browse it)
Furthermore, this Parent folder always appear in all display modes (thumbnails, list, details..), even if in Options/File list, ".." is not checked as visible. How can I get rid of it ?
2. Custom sort order by drag & drop of thumbnails works fine, but you can only drag one thumbnail at a time: I would like to move a selection of files (like in ACDsee !). (Custom sort order stored in a local file is a very good idea: easy to detect and delete, and no impact on the database size)
3. When do you think the playing of videos will be implemented ?
(I suppose it is not a bug ?)
Windows XP SP3, Nvidia 8800 GT, Athlon X2 4400+
Win 10-64, Intel i7, idsplay Dell U2413
Re: MP 0.26 and the Parent Folder
Jean_59 wrote:1. In Browser mode, XnViewMP 0.26 crashes when I click on the Open (View) Icon after selecting the parent folder Icon (..).
'Open' is not greyed??
Ok
Next version....
Jean_59
Post by Jean_59 »
Thank you Pierre,
Since I wrote this post, I moved to Windows 7 / 64 (Intel i7-860), and MP0.26 doesn't crash any more ! (in fact, when you select any folder and click "open", you only get black screen, the "open" icon is not greyed).
I still can't get rid of the ".." icon (it takes the place of 1 thumbnail and is not useful (the "up" arrrow is always near the adress bar).
Jean_59 wrote:Thank you Pierre,
Please send me your email by PM
Please check XnViewMP 0.30
