cmyk_space causes segemtation fault
Slagroom
Post by Slagroom »
I just downloaded nconvert 5.6 for Mac OS X but when I want to convert a RGB image to a CMYK JPEG I get a segmentation fault.
sh-3.2# /usr/bin/nconvert -icc_ie -cmyk_space -out jpeg -o ./images/1658.jpg ./tmp/f24973f03c2e5e547639669df344526f_4796716
** NCONVERT v5.60 (c) 1991-2010 Pierre-E Gougelet (Feb 26 2010/11:45:41) **
        Version for MacOS X  (All rights reserved)
** This is a freeware software (for non commercial use)
Segmentation fault
sh-3.2# /usr/bin/nconvert -cmyk_space -out jpeg -o ./images/1658.jpg ./tmp/f24973f03c2e5e547639669df344526f_4796716
Segmentation fault
sh-3.2# /usr/bin/nconvert -icc_ie -out jpeg -o ./images/1658.jpg ./tmp/f24973f03c2e5e547639669df344526f_4796716
Conversion of ./tmp/f24973f03c2e5e547639669df344526f_4796716 into ./images/1658.jpg OK
original image info:
Array
    [0] => ** NCONVERT v5.60 (c) 1991-2010 Pierre-E Gougelet (Feb 26 2010/11:45:41) **
    [1] =>         Version for MacOS X  (All rights reserved)
    [2] => ** This is a freeware software (for non commercial use)
    [3] =>
    [4] =>
    [5] => ./tmp/f24973f03c2e5e547639669df344526f_4796716 : Success
    [6] =>     Format               : JPEG TrueColor (v1.1)
    [7] =>     Name                 : jpeg
    [8] =>     Compression          : JPEG
    [9] =>     Width                : 800
    [10] =>     Height               : 709
    [11] =>     Components per pixel : 3
    [12] =>     Bits per component   : 8
    [13] =>     Depth                : 24
    [14] =>     # colors             : 16777216
    [15] =>     Color model          : RGB
    [16] =>     Bytes Per Plane      : 2400
    [17] =>     Orientation          : Top Left
    [18] =>     Xdpi                 : 72
    [19] =>     Ydpi                 : 72
    [20] =>     Page(s)              : 1
    [21] =>     Metadata             : ( EXIF ICC )
    [22] =>     Color Profile        : Display
    [23] => EXIF:
    [24] =>   Camera:
    [25] =>     Orientation          (0x0112): top-left (1)
    [26] =>     X Resolution         (0x011a): 72
    [27] =>     Y Resolution         (0x011b): 72
    [28] =>     Resolution unit      (0x0128): Inch
    [29] =>   Image:
    [30] =>     EXIF image width     (0xa002): 800
    [31] =>     EXIF image length    (0xa003): 709
What am I doing wrong?
Re: cmyk_space causes segemtation fault
Could you send me the file?
Slagroom
Post by Slagroom »
I have send it to your wanadoo mail.
Slagroom wrote:I have send it to your wanadoo mail.
please use contact at xnview dot com
Slagroom
Post by Slagroom »
Okay, i send it to you
