Hello. I have a few suggestions when writing PCL files.
NEEDED:
- Specify paper size: e.g. A4 (ESC &l26A) (optionally specify input tray - should default to auto = 0)
- Specify orientation: e.g. Portrait/Landscape
OPTIONAL:
- Duplex mode printing: long-side and short-side binding.
E.g. simplex -> ESC &l0S
long side duplex -> ESC &l1S
Short side duplex -> ESC &l2S
- Some additional options (staple, punch, et cetera). Difficult to implement. We are probably talking using PJL Job commands here (not sure).
It could be also cool if some page layout would be shown on screen before generating the file.
Thanks in advance. XnView is great.
Save As PCL Suggestions
eL_PuSHeR
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
GeForce GTX 970 (Gigabyte)
8 GB DDR4 (2100)
eL_PuSHeR
Re: Save As PCL Suggestions
I forgot to add that PCL should support multi-pages too.
Intel i7 5960X
8 GB DDR4 (2100)
8 GB DDR4 (2100)
