Saving UI Color and Layout Settings
XnView4U&ME
Post by XnView4U&ME »
Hi, Just found out about XnView from another forum yesterday :P Previously I have used picasa but it's no where near as cool
I've customized the colors and layout on my interface and found a link on this forum for Tweak UI and customized some more. However it has since reverted and as an amateur I mess around with windows a lot so it's sure to keep happening.
Basically I wanna know is there a way at all to save these changes so I don't have to do it manually every time? For either or both tool panel and XnVeiw Tweak UI that is? And how do I do it? :P
Thanks
oops66
Re: Saving UI Color and Layout Settings
Post by oops66 »
XnView4U&ME wrote:...Basically I wanna know is there a way at all to save these changes so I don't have to do it manually every time? ...
Thanks
here it is:
(The most important file is xnview.ini)
http://newsgroup.xnview.com/viewtopic.php?p=6230#p6230
XnView Tweak UI :
http://newsgroup.xnview.com/viewtopic.php?f=61&t=19160
XnView4U&ME
Ok gotcha. Thanks Oops. :D
