System:
- Windows XP SP-3, German, logged in as local Administrator
- XnView 1.97.2 and 1.97.3
Performed Action:
1. Set the main window to a list view
2. Selct in the folder window a folder with subfolders, containing raw image files and 2 GPS log files (*.nmea, *.tk1)
3. Select in the main window two subfolders of selected folder
4. Select function "tools" -> "batch renaiming"
5. Set "Name Template" to <Model><Filename>
6. Set Replace "Canon" with "" (nothing)
7. Check Preview of File renaming: Everything looks perfect, only CR2-Files selected (as desired)
8. Click Rename
Expected Result:
a) Renaiming completed
Found Result:
a) Renaimung completed (job done - perfect!)
b) XnView crashes.
Remarks:
No reasons for crash visible
No messages returned
No damage of renamed files found.
Crash after batch rename
bernieburnham
Re: Crash after batch rename
I also have been experiencing a very similar problem using slightly different settings but still the basic problem is the same. Yet there seems to be a way round the problem.
'Error': When selecting a folder in order to perform Batch Rename upon all images within and then selecting 'Batch Rename' either from the Tools menu or the right-click menu, it performs its actions exactly as expected, except a split-second after completing it crashes, producing the friendly "Windows is checking for a solution to the problem" dialog box. Having had to perform Batch Rename individually on 49 folders, this problem only failed to occur three times.
'Non-error': However, when performing this task by entering the folder, selecting all images and then entering 'Batch Rename' (either from the Tools menu or the right-click menu), the problem no longer occurs. This was so for the remaining 18 folders for which I tried the procedure.
Similar to 'MyUserName' (inventive username by the way), 'Error' leaves nothing unexpected behind, and produces no noticeable damage to the images involved. I am using Windows 7, logged on as local Administrator, and using XnView version 1.97.4. I hope the information provided can help in fixing the problem.
Could you send me your email by PM? I would like to send you a test version?
