I just installed a fresh Xubuntu 10.04 AMD 64bit on my hp dv4 laptop, and try to run the newest xnview 0.26, but fail to start.
The output says:
sh xnview.sh
./xnview: error while loading shared libraries: libstdc++.so.6: cannot open shared object file: No such file or directory
However the libstdc++ is already installed in the usr/lib dir as "libstdc++.so.6" links to "libstdc++.so.6.0.13".
In contrast, the program runs fine on my other PC under Xubuntu 9.10 32bit.
MP 0.26 Linux: Cannot start Xnview (64bit system)
zflyer
zflyer
Re: MP 0.26 Linux: Cannot start Xnview (64bit system)
I think I find the solution, after install the 32bit wine, it comes with the 32bit version of libstdc++.so.6, in synaptic is called " lib32stdc++6".
