File size not shown for non-image files
Dreamer
In thumbs and labels view the file size is not shown for non image files. I'm not 100% sure it's a bug, but I think the size should be shown for all files.
Dreamer
Re: File size not shown for non-image files
I can't reproduce this one
JohnFredC
You use Cache DB? Settings in Browser/File list?JohnFredC wrote:Confirmed:
JohnFredC
Folder shown is cached.
Not sure how to answer your other question. 4 checks enabled in the video item row of the file list.
My guess is that it has something to do with the position of the file size within the label.
Perhaps XnView only checks the first field and suppresses the entire label row if the first field doesn't match the file type.
John
Dreamer
Almost... "File size" works, but any "Custom" size (<Size KB> or <Size auto>) doesn't work, even if it's the only item there.JohnFredC wrote:My guess is that it has something to do with the position of the file size within the label.
Dreamer
- Forum Librarian
Yes, because all fields are not here... You'll have something like "0x0 - xxxxxxx KB"Dreamer wrote:Almost... "File size" works, but any "Custom" size (<Size KB> or <Size auto>) doesn't work, even if it's the only item there.JohnFredC wrote:My guess is that it has something to do with the position of the file size within the label.
JohnFredC
