Why dont the view option work?
ello
Post by ello »
I'm trying to get these icons to load and work, things like cut, copy, past, etc.. I'm selecting the buttons and nothing is working.
Uploaded with ImageShack.us
ello
Re: Why dont the view option work?
Post by ello »
Also, I noticed that when I select one of the icons, like the Magnifer fo example, in the line that says, "Command:" cmd_ZoomIn appears
But in the next line that says, "Icon file:" I'm not sure where or what I am supposed to browse to.
Help Me Please
The toolbar in view mode doesn't change?
ello
Post by ello »
xnview wrote:The toolbar in view mode doesn't change?
No it will not change for me.
I'm running Windows 7 home basic 64 bit
i dont know what to do???
Which toolbar do you have in view mode?
ello
Post by ello »
Okay, I'm embarrassed to explain this but I owe it I feel.
"view mode" I just discovered what "view mode is"
yes, this does work in the "view mode"
I was under them impression that the screenshot I posted was the "view mode" oops, sorry for the misunderstanding, at any rate 'm slowly getting the hang of XnView and I love it, this is the program for me. I'm using it more or less to see my art before I open it in Photo shop or Paint shop, more or less as a way to keep my files organized.
Last question? Is there a way to edit and or add functions to the small tool bar that you can make appear above the thumbnails? I'm not talking about "view mode" I mean the interface that preloads with XnView. I hope this question makes sense.
Thanks in advance
