Hey,
I'm labeling every foto that i have (about 6000).
I addes keywords and categories into the IPTC.
To add those i use XNview. There is a categorie tab to see the foto's but is dus nog uses the categories of the IPTC tag.
I wish XNView has a vieuw in which you can see the categories u used in the tags and also the keywords.
For example: i have lots of pitures of friends, i gave them the categorie "friends" in the tag. I also added the friends name as a keyword in the tag.
Now i want a simpel viewer in which i can click on the keyword (name of my friend) to select every foto of him/her.
Is it possible to add it on XnView?
Wouter
IPTC
oops66
Re: IPTC
FYI: You can already do that with XnViewMP v0.26 (beta project) not yet with XnView Windows v1.9x (but you can use the Tools\Search function)
http://newsgroup.xnview.com/viewtopic.php?f=60&t=19759
wouters2
Re: IPTC
Thanks for the info. The search is indeed working!
I guess i have to wait for the "categorie" function function in the windows app.
I hope that they build it quick because i could not find any other programm that could do the trick.
Wouter
Wouter
