Lucid Lynx and XnViewMP beta 0.26
michaauskiel
Post by michaauskiel »
I'm using Ubuntu Lucid Lynx (64bit). It seams that XnViewMP beta 0.26 is not running with this system, right?
oops66
Re: Lucid Lynx and XnViewMP beta 0.26
Post by oops66 »
michaauskiel wrote:Hi,
No, I guess it's ok, see here from French theard:
(But The 64 requires the installation of 32-bit libraries.)
http://translate.google.fr/translate?hl ... Fxnview_mp
http://doc.ubuntu-fr.org/xnview_mp
mahikeulbody
Post by mahikeulbody »
I am using XnViewMP beta 0.26 with Ubuntu Lucid Lynx (64bit).
I installed it thanks to this link : http://doc.ubuntu-fr.org/xnview_mp
where you can found a .deb 64bits (http://hizoka.funcenter.fr/linux/XnViewMP_0.26_64.deb)
oops66
Post by oops66 »
mahikeulbody wrote:I am using XnViewMP beta 0.26 with Ubuntu Lucid Lynx (64bit).
Right, and FI, also the latest MP0.26 32bits .deb version:
http://hizoka.funcenter.fr/linux/XnViewMP_0.26_32.deb
PS: The .deb files are located on a private ftp (more or less busy), so it is possible than the download can be slow, if so try again 30 minutes later if problems arise.
You can also build your own .deb:
http://forum.ubuntu-fr.org/viewtopic.php?pid=3369442
http://doc.ubuntu-fr.org/xnview_mp#crea ... er_control
michaauskiel
Yes, it works just fine! Thanks
wubijacq
Post by wubijacq »
In the debian package xnviewmp for lucid 64bits you must have in DEBIAN control the line Depends: ia32-libs (>=2.7ubuntu25) see here http://newsgroup.xnview.com/viewtopic.php?t=18968 :arrow: and change the line Depends. You cannot install the hizoka (or others) DEB karmik xnviewmp0.26b 64bit on the lucid linx version cause of different ia32-libs (incompatibility) we just can do that with DEB xnviewmp0.26 32bit. So we do not really need deb, rpm, yum. With the tarbal that Pierre done for linux it is very easy to install and test XnViewMP on any linux distro. You just have to Download the archive, Save on a directory, Extract here. Then go to the file xnview.sh double-click on it and Run. For the very beginners a tuto at http://www.wubijacq.com/topic3/.
