"Copying to" and "Moving to" from Folder in Folder tree pane
josedumoretzsohn
Very often I edit a folder (batch renaming, reordering and other) and need to backup or move around the newly edited folder altogether, and for this purpose I need to select all images inside the folder and copy or move them to the backup folder or a new position. Instead, would it be possible to insert "Copy to" and "Move to" (and "Copy" and "Move" too) in the mouse right-click context menu so that these operations can be commanded straightly from the folder icon in the Foldertree sidebar ?
Re: "Copying to" and "Moving to" from Folder in Folder tree
You have already "copy/move to folder" in the context menu!!
JohnFredC
houpsJohnFredC wrote:Not in the tree!
