When I delete RAW, will be deleting JPG with same name
When I delete RAW, will be deleting JPG with same name. How can I disable this? Thanks a lot!
Re: When I delete RAW, will be deleting JPG with same name
Hello,Pinguin wrote:When I delete RAW, will be deleting JPG with same name. How can I disable this? Thanks a lot!
It depends:
companion files setting into xnview.ini:
[File]
CopyCompanionFile=0
(1= with a link, 0= without link)
oops66, thank you! It works!
Thank you, that was it. Funny i tried to do a search before posting so that I didn't waste anybodys time, but didn't find that link.
