i have an old DOS-box which runs a good old measurement software and the screen output are saved in a *.PIC file.
but none of the formats which xnview or irfanview can handle.
I have a own dos pp.exe file to convert those files to a *.pcx. then it is fine to load it within xnview
and do whatever we want.
how can I make my "plugin" or "read-script" for those files?
I want to double click the *.PIC and the conversion should run before the image comes to xnview as a pcx.
somewhere into the options and run scripts..?
what i tried did not run because xnview first want to open and then run the pp.exe?
i am not a computer genius.. as you may have recognized.
thanks for your help
lukas
oldPIC format and pp.exe file to convert
Re: oldPIC format and pp.exe file to convert
The only way is to make a plugin with PluginSDK
You can perhaps send me some samples, too?
