I need to scan a few pages and save them into 1 pdf file (instead of many pdf files).
I am using
File->Acquire into..
then checked 'save as multipage' and selecting PDF format. However, I only find tmp_xnview-1.png and tmp_xnview-2.png in the output directory.
It works if I change the format to TIFF but not PDF. Any suggestions?
Thanks,Fabian
multipage pdf creation
Re: multipage pdf creation
Strange, which version do you have?
tbyeoh
I have 1.97.4 .
Libformat ver 5.62.
I have tried it on 2 computers - 1 winXP and 1 vista. Both show the same issue.
Fyi, I am running this on the Canon D480 all-in-one which is connected as a network scanner.
Thanks in advance for your help!
Libformat ver 5.62.
eL_PuSHeR
As far as I know multi-page creation is only for TIFF. Correct me if I am wrong.
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
GeForce GTX 970 (Gigabyte)
8 GB DDR4 (2100)
No PDF tooeL_PuSHeR wrote:As far as I know multi-page creation is only for TIFF. Correct me if I am wrong.
I've tried again, and can't reproduce
Drahken
Consider yourself corrected. :peL_PuSHeR wrote:As far as I know multi-page creation is only for TIFF. Correct me if I am wrong.
Xnview can create multipage files in several different formats; tiff, pdf, ldf, windows icon, photoshop, and zsoft paintbrush.
eL_PuSHeR
Forgive me. I was misunderstood. I meant when acquiring pages using an scanner.
Intel i7 5960X
8 GB DDR4 (2100)
8 GB DDR4 (2100)
Drahken
Well, you should be able to use the same multipage formats when acquiring from scanner, there's no real reason why it would be otherwise. Unfortunately I can't test that myself since I don't have a working scanner to hook up.
eL_PuSHeR
On the acquire window it says only TIFF can be used for multipage.
Intel i7 5960X
8 GB DDR4 (2100)
8 GB DDR4 (2100)
