How to start slide show?
n2rpb
Post by n2rpb »
Frightens me when I see all the tech questions asked when mine might appear stupid but... how do I start the slideshow ?
Once I have the folders opened how do I start it Previous version I used had the word 'Go' at the bottom. Now it just shows 'Open'.
Alternatively how can I reload an older version with the box that reads GO ?
marsh
Re: XnView 1.97
Post by marsh »
n2rpb wrote: Once I have the folders opened how do I start it Previous version I used had the word 'Go' at the bottom. Now it just shows 'Open'.
The latest has go button at lower left. Perhaps your screen resolution is low (800x600), and it is off-screen?
If so, there are workarounds:
a. With files highlighted in selction window, press <enter>
b. Press <tab> key until open button is in focus, press <tab>key 4 more times and press <enter>.
c. See if OS can drag window partially off-sceen hopefully making buttons visible.
d. Use small fonts instead of large.
