Heh heh more than a suggestion it's a little bitching...
I like to print files from Irfanview because I like its print menu a lot. Easy and convenient. I find Xnview's one a little chaotic.
Print dialog Irfanview style
eL_PuSHeR
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
GeForce GTX 970 (Gigabyte)
8 GB DDR4 (2100)
Re: Print dialog Irfanview style
What do you means by chaotic?
eL_PuSHeR
Hmm. Too many options maybe and not very tidy. This is just a wild assumption on my part, though.
One thing I don't know how to accomplish: I use multipage files a lot. Sometimes I only need to print a range of pages. How can it be done with Xnview?
Intel i7 5960X
8 GB DDR4 (2100)
8 GB DDR4 (2100)
Right, no such option, i'll add iteL_PuSHeR wrote:One thing I don't know how to accomplish: I use multipage files a lot. Sometimes I only need to print a range of pages. How can it be done with Xnview?
I think that XnView's print dialog is pretty clean and clear. It's probably just a matter of what you are used to.
eL_PuSHeR
You are probably right.
Intel i7 5960X
8 GB DDR4 (2100)
8 GB DDR4 (2100)
