When I try to convert to images from 1.tif and 2.tif to 3.tif as a multi frame picture XnView reports an error. The message reads (translated from German): "Error creating file "c:\...\3.tif" The compression LZW is used, Format is Tiff 6.
Both source tifs are monochrome 600 dpi (created from greyscale within XnView). But it also does not work for gif to tif and anything else I tried.
Rolf
Edit: it's even worse. I just scanned a multi-frame tif and XnView can't open it (unknown file format). I can open the file and look at all frames with other programs, like windows picture viewer etc.
Can't convert to multi-frame Tif
Re: Can't convert to multi-frame Tif
Could you send me your tif files?
