First I would like to thank the developers of XnView, its a tremendous piece of software that I use everyday!
I have a couple of 8-bit raw files which are loaded incorrectly by XnView. Photoshop CS4 can open them perfectly.
Example file: http://rapidshare.com/files/393183780/8 ... e.raw.html
Thanks in advance.
8-bit raw image not loading correctly
Re: 8-bit raw image not loading correctly
Do you have changed size/format in options/Read/RAW?
zugzwang
Ahh, now it worked! I had to manually set the image dimensions and change channel type from RGB to grayscale.xnview wrote:Do you have changed size/format in options/Read/RAW?
Maybe XnView could open a window for us to inform these values automatically when we open raw files (as Photoshop does)? And it could use some kind of heuristic to estimate the size of the image (as Photoshop does too)?
Another question, does XnView support 16-bit raw images?
[quote="zugzwang"
Another question, does XnView support 16-bit raw images?[/quote]
Not yet
Not yet
