slide show with canon raw files issues
drugo
Post by drugo »
Hi to all
i have a issue
well I download xnview zip file this one http://download.xnview.com/XnView-win.zip
and it's an amazing program!!!!
and i run and it works great
i setup for raw embedded thumbnails in every place in the preference
now one thing i noticed that's weird is that is more fast open/view a raw file then a jpg file :shock: :shock: :shock:
well my issue is the slideshow , i have tha last official xnview version
my canon raw files look ugly in the slideshow (less contrast , different colors ) different compared to the view mode
i got a 5d mark2 and a 40D and both only in the slideshow the raw files look worse
is there something that can i do to fix it?
or is a small bug of this version?
best regards !
ps thanks for activated my account
Re: slide show with canon raw files issues
drugo wrote: i setup for raw embedded thumbnails in every place in the preference
The embedded picture in RAW is often smaller
Could you send me a sample to test?
drugo
Post by drugo »
yes canon 5d mark2 are 22mb and 40D 12mb
where could i upload ?
for now you can grab one here http://75.126.132.154/PRODS/E40D/FULLRE ... RI0100.CR2
thanks a lot
drugo wrote: for now you can grab one here http://75.126.132.154/PRODS/E40D/FULLRE ... RI0100.CR2
Right it's a bug
drugo
Post by drugo »
Right it's a bug
thanks
i guess it happen only in the slideshow
