Lost tag info. after moving files to another folder
Newtimes
Post by Newtimes »
is there anyway to restore the tags and ratings back to the files I moved around?
I did click show all tagged files, but no luck the ones which I had moved did not show up
thanks in advance
Chris :? :? :(
Re: Lost tag info. after moving files to another folder
Yes, currently it's a known issue
I've checked, and tag is not lost. Did you move the files with drag&drop or Alt+M?
