Support for TXC files
tekken57
Post by tekken57 »
Hi, i'd like to request support for txc fles which is the native format used by the ps2 smackdown games. The graphics are basically tm2 files with a custom header.
I am able to edit the files by replacing the header with a tm2 header based on the dimensions of the image. As you can imagine it is a lengthy process to convert to tm2 and back to txc for each file. It would be great if we could view and edit the txc files directly in xnview.
Here are few samples: http://www.mediafire.com/download.php?mn2dtwnifng
Thanks for any help rendered.
Re: Support for TXC files
ok, i'll try to add this format soon
