Thumbnails do not show pictures
Meuchael
Post by Meuchael »
Hello!
I make 3D- (anaglyph) pictures by means of Anabuilder (two jpg.-photos put together) and save them as normal (i think) jpg-files. Thumbnails of most of them are shown as abstract paintings :shock: in XnView (In e.g. Total Commander there are no problems). There are files bigger and smaller which are shown normally, so it isn't the size. Does Anabuilder possibly code some of the pictures in some way, although they have normal extension? I use the latest update together with Windows7.
Besides the above Xn-View has worked very satisfying for me. Thanks a lot.
Re: Thumbnails do not show pictures
Could you send me a sample?
