XnView 1.97.5 doesn't show up folders in viewer
aha
Post by aha »
XnView 1.97.5 doesn't show up my folders on W2K. Neither those on partition C nor those on other partitions.
I've made a screenshot to illustrate my problem:
ckv
Re: XnView 1.97.5 doesn't show up folders in viewer
Post by ckv »
Confirmed :bugconfirmed:
On Windows XP and Vista folder tree works , but on Windows 2000 it is broken.
:bugconfirmed:
Right only on OS before Xp
aha
Post by aha »
Many thanks for the prompt fix :)
