RC2: BUG minor: Thumbnail & Details view focus
Dreamer
Post by Dreamer »
When I switch from any view to Thumbnail & Details view or from Thumbnail & Details view to any other view, with F9, tollbar button (also submenu), folder/file position/focus is lost.
ckit
Post by ckit »
I can confirm this bug after using F9 about 5 times.
Dreamer
Post by Dreamer »
Moved:
Post by marsh
RC2: ".." folder disappears from detailed list F9
".." folder disappears from detailed list when changing views with F9 with the following options:
'Items shown in thumnail mode' ...all blank
'Items shown in other mode'...Folders flagged with all others blank
This folder should reappear when cycling with F9 instead of vanishing.
Post by OL
Curiously it sometimes work and sometimes doesn't work. Curently I can't reproduce, but i've already seen this.
Post by ckit
This is the same bug as Dreamer's post - http://newsgroup.xnview.com/viewtopic.php?t=2021
Therefore moved here ;)
[Fixed?] Re: RC2: BUG minor: Thumbnail & Details view fo
Dreamer wrote:When I switch from any view to Thumbnail & Details view or from Thumbnail & Details view to any other view, with F9, tollbar button (also submenu), folder/file position/focus is lost.
Dreamer
Re: [Fixed?] Re: RC2: BUG minor: Thumbnail & Details vie
Post by Dreamer »
Dreamer wrote:
I'll fix it ;-)
marsh
Post by marsh »
marsh wrote: RC2: ".." folder disappears from detailed list F9
Still a problem in RC3.
I can't reproduce it, what do you make exactly?
marsh
Post by marsh »
xnview wrote: I can't reproduce it, what do you make exactly?
".." folder disappears when:
'Items shown in thumnail mode' ...nothing selected
'Items shown in other mode'...only folders selected.
So, folders must be selected in both thumbnail and other mode for ".." folder to remain displayed.
Dreamer
Post by Dreamer »
xnview wrote:
Dreamer wrote:
xnview wrote:
I'll fix it ;-)
OK, my bug is fixed in RC3.
marsh
Post by marsh »
In addition to disappearing ".." folder, I get lines through names. My options
are listed in previous article. And the list seems offset vertically. Notice how
list gets tucked under buttons. The list had only 13 files, so a vertical scrollbar was not needed.
ckit
Post by ckit »
I've seen that bug recently too,
only with RC3 but I can't re-produce it so far.
marsh wrote: Image
I've seen it too one time, but can't reproduce anymore.
What do you make? Which OS do you have?
marsh
Post by marsh »
xnview wrote: I've seen it too one time, but can't reproduce anymore.
I'm using Win2k SP4. I recreated the 'lines through names' by using F9 to cycle through views, and options as shown above. I have preview on left, file list on right, disabled folder tree, 800x600 resolution.
Dreamer
Post by Dreamer »
Locked
