XnView cannot see folders in mounted TrueCrypt volume
JohnFredC
Post by JohnFredC »
TrueCrypt users:
Create a TrueCrypt volume and mount it.
Use a file manager (such as TC or Explorer) to make some folders inside the volume.
Start XnView (1.97.5) and attempt to browse a folder in the TrueCrypt volume.
The volume appears with its assigned drive letter and the folder tree shows the "+" to indicate that folders are present, but the folders themselves are not visible.
TrueCrypt folders are not visible from XnView MP 0.26.1, either, but with MP the "+" is not visible next to the volume name in the tree.
John
Dreamer
Re: XnView cannot see folders in mounted TrueCrypt volume
Post by Dreamer »
Can't confirm, but the hidden folders are not visible in the folder tree (completely, no "+") :bug: . In the file list they are visible. (TrueCrypt volume only)
In MP it's the same, but when I enter a hidden folder, this folder is shown also in the folder tree, in Win version doesn't.
BTW there is no indication for hidden folders/files. I think it has been already requested, it would be really useful.
Dreamer
