Unable to Change Orientation
maudale
I can't change the Orientation in the Properties window's EXIF tab. The Apply button is grayed out. I have done this in the past, but can't figure out why it's not available now.
Re: Unable to Change Orientation
Is it a jpeg?maudale wrote:I can't change the Orientation in the Properties window's EXIF tab. The Apply button is grayed out. I have done this in the past, but can't figure out why it's not available now.
maudale
Yes.xnview wrote: Is it a jpeg?
Could you send me it?maudale wrote:Yes.xnview wrote: Is it a jpeg?
maudale
This happens with many different files from different cameras and are not read-only.
So please, send me a sample?maudale wrote:This happens with many different files from different cameras and are not read-only.
maudale
Here is a link to a sample:
http://www.movingtofreedom.org/images/2 ... monkey.jpg
I figured out that I can change it in the Preview Pane, but not the Properties window.
You try to change it in the Preview pane, right?maudale wrote:I figured out that I can change it in the Preview Pane, but not the Properties window.
maudale
It does work in the Preview pane. Is it supposed to work in the Properites window also?
nomaudale wrote:It does work in the Preview pane. Is it supposed to work in the Properites window also?
