The jpg files in neighbourhood with cr2 files freeze few seconds before closing and the XnView doesn't respond.
Say, there are 0207.jpg, 0208.jpg, 0209.cr2, 0210.cr2, 0211.cr2, 0212.jpg and 0213.jpg files. The files 0208.jpg and 0212.jpg are closing too slow once opened. No problem with other jpg ones.
Same problem with 1.97, 1.97.2 or 1.97.5 versions. Running Vista Ultimate+XnView Zip version (portable).
Strange behaviour with some jpg files
Re: Strange behaviour with some jpg files
XnView try to load the next file, so cr2. If you close XnView, and file not yet loaded, you can have a little delay.
option/View/Misc/Read ahead
Nabu
Thanks. Unticking the "Read ahead" box solves the problem.
