0.26 Linux: Crash on start
kotyz
Post by kotyz »
XnViewMP crashes on start/fails to start.
The output in terminal says:
[kotyz@behemot ~]$ xnviewmp
Cannot mix incompatible Qt libraries
/usr/bin/xnviewmp: řádek 7: 6274 Neúspěšně ukončen (SIGABRT) $dirname/xnview "$@"
I have Arch Linux (32bit) with Qt 4.6.3.
Re: 0.26 Linux: Crash on start
please use the .sh to start xnviewmp
kotyz
Post by kotyz »
Still the same problem when I start xnview using xnview.sh
[kotyz@behemot XnViewMP-026]$ ./xnview.sh
./xnview.sh: line 7: 12266 Aborted $dirname/xnview "$@"
Which files do you have in the XnViewMP folder?
kotyz
Post by kotyz »
[kotyz@behemot XnViewMP-026]$ ls -la
total 5904
drwxr-xr-x 6 kotyz users 4096 Mar 16 14:15 .
drwxr-xr-x 11 kotyz users 4096 Jun 21 22:43 ..
drwxr-xr-x 4 kotyz users 4096 Mar 30 16:03 AddOn
drwxr-xr-x 2 kotyz users 4096 Oct 2 2009 Plugins
-rw-r--r-- 1 kotyz users 198 Mar 16 14:00 README
-rw-r--r-- 1 kotyz users 247 Mar 16 13:58 XnView.desktop
-rw-r--r-- 1 kotyz users 3945 Sep 28 2009 country.txt
drwxr-xr-x 2 kotyz users 4096 Mar 30 15:30 language
drwxr-xr-x 3 kotyz users 4096 Mar 16 14:03 lib
-rwxr-xr-x 1 kotyz users 5984720 Mar 30 15:29 xnview
-rwxr-xr-x 1 kotyz users 155 Mar 16 14:03 xnview.sh
Where are the Qt libs?? You have downloaded my archive??
kotyz
Post by kotyz »
Qt libs are in the lib subdirectory inside the XnViewMP-026 directory.
I downloaded the xnviewmp archive from here: http://download.xnview.com/XnViewMP-linux.tgz
kotyz wrote:Qt libs are in the lib subdirectory inside the XnViewMP-026 directory.
In the package the library are not in lib folder :-)
bootmaker
Post by bootmaker »
I upgrade qt4 from qt-4.6.2 to qt-4.6.3. Linux version: Gentoo.
xnview.sh say:
update links from /opt/Xnview/lib/libQtxxxxxXn.so .4 to /usr/lib/qt4/libQtxxxxx.so.4 no take effect.
xnview.sh say:
w.init
########### BrowserWindow :: BrowserWindow
MENU install : 86b0cf0
Object::connect: No such signal MyThumbThread::thumbUpdated(int)
QLayout: Attempting to add QLayout "" to QWidget "", which already has a layout
Object::connect: No such signal MyThumbView::thumbUpdated(int, const QImage&)
QMainWindow::setCorner(): 'area' is not valid for 'corner'
########### BrowserWindow :: ok create (640 480)
/opt/XnViewMP/xnview: symbol lookup error: /opt/XnViewMP/xnview: undefined symbol: _ZN11QMainWindow13changeMenuBarEP8QMenuBar
