Image in clipboard breaks Imageshack function
windozer
Post by windozer »
When there's an image in the clipboard, then XnView's shell extension executes the wrong command from the context menu when choosing "Send to Imageshack". It always executes "Save clipboard to file" as long as there's an image in the clipboard.
To reproduce this:
1. Take a screenshot with the print key on your keyboard, so that the screenshot is copied to the clipboard
2. Now right-click on an image file, doesn't matter which, and choose "Send to Imageshack". Instead of displaying the dialog to send the file to Imageshack, it will create an image file of the clipboard content. Obviously, XnView is executing the command "Save clipboard to file" instead of "Send to Imageshack". This only happens when there's an image in the clipboard.
OS: Windows XP SP3 Professional 32-bit
XnView v1.97.6 (full version with ShellEx)
