[solved] Command launching
lian
Sorry, I did not find any information about that. I want to launch XnView with a specific directory (not the default directory set in the options). Is there a command line to do this ?
SF, illustrations et mes BD sur mon blog: https://www.li-an.fr/
Windows 10 Home 64 bits
Re: Command launching
XnView folder
lian
Yes, it works ! Strange, I thought I did a try with that... Thank you
