Strip of images problem
canview
Post by canview »
Under "Create" and "Strip of images," when setting the number of thumbs per row for a Mozaic, any number beyond 2 per row yields a big white gap in the row. For example, for a setting of 3 per row (and, say, a Mosaic total of 6), the first 2 thumbs appear next to each other then a big gap then the 3rd thumb (in each row). How do I fix?
Re: Strip of images problem
Right a bug
canview
Post by canview »
Is the bug in my PC or the XnView program? (I have XnView v1.96.) Suggestions how to fix? I tried your horizontal-horizontal-vertical merge technique for 2 rows of 6 pics, 3 per row, but when I tried vertical for the final merge, I got only a single vertical strip of 6 pics. Apppreciate any help you can provide because I like XnView & would like to use image strips for the many digital camera sequences I take.
i means that it's a problem in xnview, i'll fix it
canview
Post by canview »
Pierre,
I look forward to your fix! Any idea when you can do it? Thanks!
Canview
canview wrote:Pierre,
Canview
I'll try to fix it in next release...
Please try XnView 1.97.7
canview
Post by canview »
xnview wrote:Please try XnView 1.97.7
Pierre,
Thanks much! I downloaded/installed your new v. 1.97.7, and that solved the "strip of images problem." Worth waiting for!
Canview
