Some suggestions for multipage TIFF
eL_PuSHeR
Post by eL_PuSHeR »
Hello. I would like to suggest the following when using multipage TIFF files.
1.- Go to a page. I don't know if it can be already be done. I have searched the menus and didn't find anything.
2.- Option to select compression when extracting pages from a multipage TIFF. No need to go to configuration to check write compression setting for TIFF.
3.- Progress bar when extracting pages.
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
GeForce GTX 970 (Gigabyte)
Re: Some suggestions for multipage TIFF
Menu & keyboard shortcuts:
  • View » Page:
    • Next (Shift+PageDown)
    • Previous (Shift+PageUp)
    • First (Shift+Home)
    • Last (Shift+End)
    • Open Page Number...
Keyboard:
  • Tools » Options... » General » Keyboard/Mouse » Keyboard/Mouse » Keyboard:
    • Cursor Up/Down [ Previous/Next frame ]
Toolbar:
  • Tools » Options... » Interface » Toolbar » Buttons » Buttons displayed » View:
    • cmd_NextPage
    • cmd_PreviousPage
    • cmd_FirstPage
    • cmd_LastPage
    • cmd_Page
eL_PuSHeR
Post by eL_PuSHeR »
Thanks. I was guessing it could be done somehow.
Intel i7 5960X
8 GB DDR4 (2100)
NoName
Post by NoName »
Would be good to add on the left panel sketches for multipage TIFF files, so you can see thumbnails of pages and quickly move to the right. Same panel as for example in Microsoft Office Document Imaging.I would appreciate your attention to this matter.
admirer
Post by admirer »
I support previous suggestion -- thumbnails of multi-page TIFF (and, may be) PDF will be very usefull.
Also I can't add page-control buttons to Browser Toolbal (cmd_PreviusPage, cmd_NextPage, cmd_Page) (in View Tollbar in works fine).
Any chances to have this functionality later in XnView?
