[Solved] Image-Properties: "Color Model" in 1-bit TIF
Peter2
Post by Peter2 »
Bug or feature?
Starting the discussion here "Defining a scan-job for Repro-shop"
http://newsgroup.xnview.com/viewtopic.p ... 51&p=84298
there was a question:
Is it correct that a TIF (1 bit, bw) has a "color Model: RGB"?
Please let me know.
Peter
Re: Image-Properties: "Color Model" in 1-bit TIF
Not a feature :-)
Please try XnView 1.97.7
Peter2
Post by Peter2 »
xnview wrote:Please try XnView 1.97.7
Semi solved :|
If I use the Properties in browser View it is OK. :bugfixed:
But using the properties with "Alt+Enter" display still the colour model RGB :bug:
Peter
Peter2
Post by Peter2 »
xnview wrote:Please try XnView 1.98 beta 1
Solved.
Peter
