browser/show tooltips can i have the lens used?
drugo
Post by drugo »
Hi
i can find the exif for the lens
i use a 5d mark 2 and it stored in the exif the lens used
can xnview read it?
thanks
Re: browser/show tooltips can i have the lens used?
Is it in Makernotes?
drugo
Post by drugo »
xnview wrote:Is it in Makernotes?
yes it is
for canon it's makernotes under the item lenstype , i'm checking with exifgui +exiftool
thanks
yes it is
Ok, currently Makernotes are not supported, i'll add it
But please send me a file sample?
drugo
Post by drugo »
xnview wrote:
yes it is
tell if it's enough http://web.canon.jp/imaging/eosd/eos5dm ... tscene.jpg
