I have opened a multipage TIFF image and would like to save as a multipage PDF file. However, when i click Save as.. then select PDF, a warning appears saying that only the current page will be saved? Is there a way to export the entire multipage TIF to PDF or am i doing something wrong?
Thanks,
TMT
Save as PDF
Re: Save as PDF
you can save multipage TIFF but not PDF, i'll add it
Re: Save as PDF
Please try XnView 1.97.7
TMT1
Re: Save as PDF
Thanks Pierre.
However, as there is only one compression option for PDF images, the same compression type is applied to all pages regardless of whether that page is colour or black and white. This has a massive effect on file size where there is a mixture of colour and black and white pages in the same file. Would it be possible to add a setting for black and white compression type (e.g. FAX) and a separate colour compression type setting (e.g. JPEG). This would be a massive improvement as at the moment the file size increase makes XnView unusable for this task.
Re: Save as PDF
So perhaps 2 compressions like TIFF?
