Partial jpg image not opening (xnview 1.961 and later)
budz45
Post by budz45 »
When I try to view this image:
http://www.sendspace.com/file/5gq1u6
... I get an error. This error;
But the same image opens/views as normal in Faststone Maxview;
marsh
Re: Partial jpg image not opening (xnview 1.961 and later)
Post by marsh »
By default, it does that unless setting is changed:
[Load]
IgnoreError=1
From topic, Often overlooked settings:
Q: Where is the thumbnail? It disappeared!
A: Options>General>Read/Write>[x]ignore read errors = Show thumbnail of incomplete or problem image.
Suggestion: Corrupt image indicator ?
