Open With
willgoss
Open With
Post by willgoss »
I love the Right/Click Open With......I use 4 different Graphic Editors and this is great for launching....
For some reason, after clearing all and adding the 3 main editors.....I now find 5 additional have been entered.....a couple were revised versions that I didn't add....another was a plugin for an editor again I didn't enter.......they are entered above Alt 1,2,3....
Long story there are now Alternate 1 through Alternate 8.........We need to be able to remove individual items without removing all and starting over....Am I missing something.....
Re: Open With
You can remove them in the xnview.ini
willgoss
Re: Open With
Post by willgoss »
I could not find an xnview.ini....looked in all the folders...and did a computer file search,,,,,,,
Re: Open With
Which OS do you have?
willgoss
Re: Open With
Post by willgoss »
Using Windows 7.........32 or 64
Re: Open With
willgoss wrote:Using Windows 7.........32 or 64
So in Users\LocalRoaming\AppData\...\XnView
willgoss
Re: Open With
Post by willgoss »
Thanks.....
So in Users\LocalRoaming\AppData\...\XnView .....but was in...
So in Users\UserName\AppData\Roaming\XnView\XnView.ini then Open with=0 etc......
