WMF scaling
skonik
WMF scaling
Search for some reason does not work. The question - format WMF is not scaled. Where to correct or customise? ACDSee 5.0 same file scales perfectly.
- Forum Librarian
Re: WMF scaling
Maybe this setting does what you're looking for:
- Tools » Options... » General » Read/Write » Read
- » WMF » Parameters » High resolution
skonik
Re: WMF scaling
I tried this setting. Has not helped. I will attach file WMF for tests.
On Depositfiles URL:
http://depositfiles.com/files/z248wt31h
- Forum Librarian
Re: WMF scaling
[ z00m ]
- XnView v1.97.6 @ Windows 2000 SP4
1280×960 screen resolution
“High resolution” turned off
skonik
