One XnView but different .inis?
gizzmo
Post by gizzmo »
Hi!
Once again I have discovered something strange.
I have installed XnView exactly one time, and I have one xnview.ini.
When I open images in windows-explorer, everything is as expected.
When I open images in UltraSearch (which is way more effective than the windows-search) I get an instance of the program, which plays by its own rules.
I can change settings in both xnviews and they get saved, but don't interfere with each other... as if there were two different inis, which there are not... ?
Since I almost never search for images and even if I did, I could set the settings in both xnviews the same, this is an issue of almost no importance... but it is a bit strange, so I thought I let you know about it ;)
View the Screenshot for more details:
Re: One XnView but different .inis?
Yes, strange. But it's strange too that you use xnview.ini in 'Program files'
