MP 0.26 Mac OS: some findings
cyki
Post by cyki »
capital letters in file list has influence on following features:
- type-search is not working correctly. only for first character, if it is capital
- autofocusing in file list is also not working - when you create new folder it will leaves you on top of file list
- when you want to move to parent folder from folder with first capictal letter in name, it won't focus you on selected folder but leaves you on top of file list
- sorting of files is not working well, files / directories with capical letters are sorted at the end of exact character for example Len, LEL - in this case LEL should be before Len but it isn't because of capital letters
- a little bug in contaxt menu, when you call context menu and than click left button to empty space and move mouse a little bit, then release left button, you get into select state (without holding aby button). maybe it is not bug but feature ehm, :P what do you think?
- when you open any directory with Enter, cursor will focus into Parth bar
- seems that memory handling is little bit problem because after I left bunch of images opened (350MB in memory for xnview) it chashed
Re: MP 0.26 Mac OS: some findings
cyki wrote:capital letters in file list has influence on following features:
Sorry but i can't reproduce
what do you means? You have not the focus on the text to edit?
When you type a letter?
Right...
In view mode?
Ok
Yes, known issue
cyki
Post by cyki »
- type-search is not working correctly. only for first letter, if it is capital
my picture directory consists of 291 documents and 225 folders, some of them with first letter capital, some of them entire name with capital or all lower case. most of these issues does not occur in folder with only a few files/folders
text of new directory is focused but for example when you have a lot of files in folder and view is set to thumbnail, new folder is not shown on screen thus you are not able to see what you are typing
no, when you double click on ".." or select it and hit enter. If you also have parent folder with bunch of files, you just don't see your left folder because your view is moved to the top of file list, but the folder is still selected (somewhere down below)
Right...
is this fixed in latest release?
In view mode?
in thumbnail view when you right click on white space where is no file and then you left click (and hold) again on white space (like you would like to select couple of files) and release left button, the "select status" remain until I click again somewhere else
- when you open any directory with Enter, cursor will focus into Parth bar and I can't use keyboard arrows to move selection until I click into file list
Ok
is this a feature?
cyki
Post by cyki »
maybe these bugs are not that serious but a little bit annoying :)
