Original photo labeled, needs returned
bobfey
Post by bobfey »
I made a mistake in the batch processing panel and my original photo's got labeled. I would like to convert back to the original form for the originals so I can modify or change the labels at will but not change the originals.
So the question is this. How might I do this thing of eliminating the labels in this program. I might be able to do some cropping and resizing in XnView or other photo products, but will that do the fix I am looking for.
Just need some advice on how to do this correction the best, easiest, surest, way(s).
marsh
Re: Original photo labeled, needs returned
Post by marsh »
What do you mean to describe with the term 'labels'? Metadata (Iptc, Exif, Xmp)?
Metadata can be erased from file with:
Browser menu>Edit>Metadata>Clean...
Or Clean metadata in batch convert's image transformations.
bobfey
Post by bobfey »
What I mean with Labels is to put a line of text along the bottom. I would like to keep the original photo's separate from the ones I have labeled.
You comments give me a hint of where to look. It there is something in the enclosed meta data that I can change or erase that will make things easier. I will check that lead out.
Any other ideas are welcomed too.
bobfey
Post by bobfey »
I don't know this program well enough to take chance at losing the photo's. So I used Paint Shop Pro to set up boundaries and crop to the limits, thus eliminating the text block at the bottom of the photo. It was quick, only took a couple movements and a couple clicks to perform the job. I then had PSP resize the print to the previous size. Now all is well. I have the originals and the labeled copies.
Thanks for the possible solution. Maybe when I get more experience with this product I will have a local way of fixing mistakes.
bobfey wrote:I don't know this program well enough to take chance at losing the photo's. So I used Paint Shop Pro to set up boundaries and crop to the limits, thus eliminating the text block at the bottom of the photo. It was quick, only took a couple movements and a couple clicks to perform the job. I then had PSP resize the print to the previous size. Now all is well. I have the originals and the labeled copies.
Image/Crop??
bobfey
Post by bobfey »
Was that a question or comment? If a comment, I can not find any "Image/Crop" items as Iook through the menus. If a question I will try to answer if you wish.
marsh
Post by marsh »
Are you using only browser? An area can be directly selected on image while in viewer/editor mode. Fellow users sometimes miss this and move straight on to batch processing (with less visual feedback).
Options... General>Keyboard/Mouse>Switching Modes>Use ENTER to switch between [ Browser<>Viewer ]
bobfey
Post by bobfey »
Thanks for the tip. I did try your hints and after a while I was able to get a photo on screen and it had a tool bar above it that allowed Cropping. It did not seem to be something direct in you comment; but, something that happened as I played around. I will need to take more time and see if I can map the steps to get from one area to another. As I still have not had enough time today to really learn what the path was. So thanks again as that seemed to be something missing in what I have learned about this program so far.
