Create multipage file - Won't remember last path
eL_PuSHeR
Hello. This is a minor issue for me but it's driving me crazy. I have XnView installed on four different PCs but one of them seem capable to remember last used path and last used source folder when creating multipage files. The field appears always empty. I have tried a clean installation but without success. I have checked configuration and everything seems fine. The only difference is that this XnView installation is set to Spanish language while the other ones (at least one is working) is set to English. Any ideas?
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
GeForce GTX 970 (Gigabyte)
8 GB DDR4 (2100)
marsh
Re: Create multipage file - Won't remember last path
This being on will clear the dialog's target folder:
Options... Interface>[ ]Purge most recently used files and directories on exit.
eL_PuSHeR
Thank you very much for your reply.
However I have fixed it by zipping all XnView directory (one that worked fine) and unzipping it on top on the one that was failing.
Probably the option you mentioned was enabled.
Intel i7 5960X
8 GB DDR4 (2100)
8 GB DDR4 (2100)
