Hugin EXR problem
davitof
Hugin EXR problem
Post by davitof »
Hello
I have used Hugin (and XnView too) for years but only recently decided to try to use it to generate EXR files. My problem is that the XnView does not seem to recognize the EXR files generated by Hugin. Is it a Hugin issue, or did I miss a configuration in XnView? I did check the "Use all avaliable formats" option in XnView, but maybe this is not enough?
Frederic Da Vitoria
Re: Hugin EXR problem
Do you have the OpenExr plugin?
davitof
Post by davitof »
Sorry, I thought the forum would send me a mail when there would be an answer to my question :(
No, I don't have the plugin. Yes I am now going to install it :)
Thanks for your advice
Frederic Da Vitoria
