For instance, when I select a file, then RMB Copy, the following window has a fixed size.
When you have a many folders/subfolders, you need to scroll up and down a lot.
Wud it be possible to make that window panel resizable ?
Thank you.
Make certain windows resizable
JohnFredC
mrwul
Re: Make certain windows resizable
Thanks. Actually I was not aware of such application.JohnFredC wrote:I use Sizer to enable dialog resizing in all applications.
Looks quite useful indeed!
However, I am running 64bit, the FAQ says that it will not work, regretfully.
That aside, I really hope it will not be too difficult and it will be included in the next update
