MediaDetector: Auto Rotate jpg - problem: filesize
DigiBear
Post by DigiBear »
A problem with the MediaDetector 1.7.0 (xnview 1.97.6):
Problem: The imported file are modified by the MediaDetector:
Original file size: 854.768 Bytes
New file size: 846.079 Bytes (new file is smaller !)
What I do:
I activate the Option: [x] Auto rotate JPEG images.
The file have already the Exif-Oriatation=1
So there is nothing to do, the file is not to rotate.
The bug is: MediaDetector modify the file, even though the file were not to rotate.
With out the feature "[x] Auto rotate JPEG images" the new and the old file are identical.
