Batch Rename (2)
DrNo65
Batch Rename (2)
Post by DrNo65 »
It's just a tiny bug that I've noticed with the batch rename dialog. It does not recall the space(s) added before the "replaced with" string (e.g. " S1E01") after renaming (after RENAME is clicked and the dialog is recalled once more for another rename process with old parameters).
Best regards
Re: Batch Rename (2)
Please try XnView 1.97.7
DrNo65
Post by DrNo65 »
xnview wrote:Please try XnView 1.97.7
Thanks for the reply Pierre.
The problem is not solved with the mentioned version. In order to regenerate this problem:
1 Select more than 1 file
2 press F2
3 check only the check-box "Replace"
4 in the replace text box put a character like "_"
5 put a space in the With text box
6 Click "Rename"
7 Select more than 1 file
8 press F2
The character in the With text box is still there BUT the "space" character in the With text box is GONE
This case will not happen if the character in the "With" text-box is something else OTHER than SPACE.
Merci pour vos efforts et bon fin de semaine.
