Batch rename crashes (v1.97.6)
StephanP
Post by StephanP »
On two different computers both running W7, I am experiencing crashes when using the Batch Rename function.
  • select a series of images
  • Name template: <Folder name>-###
  • Sort: by EXIF Date
  • Rename
Almost immediately I receive a crash report from Windows, stating that XnView needs to be closed.
When I check the folder, the rename action has been performed alright, so the crash must have occurred shortly after that, before returning to the XnView GUI.
Stephan
marsh
Re: Batch rename crashes (v1.97.6)
Post by marsh »
Confirmed. Crash occurs with rename's sort by Exif date; browser in details view; 'scan file headers' option off.
For me, using thumbnails or turning on header scan option avoids problem.
Please try XnView 1.97.7
StephanP
Post by StephanP »
Problem solved.
Thanks,
Stephan
