Slide show with music background on cd
guenter
Post by guenter »
burning a slide show with background music on cd (autorun.inf) like recommended in XnView help, there is no sound to be heard. What can I do to listen to the music while looking to the pictures?
Regards
guenter
Re: Slide show with music background on cd
The problem is only if you burn it?
Pierre, I believe it's the issue discussed in “Lecture Audio en Diaporama CD”.
