I would like to report a problem I have discovered with XnView and certain JPEG 2000 (.JP2) files.
XnView with the JasPer JP2 plug-in always crashes on reading JP2 files with custom profiles embedded. These files have embedded display profiles created with a Spyder2 colorimeter. This is a somewhat unusual practice, but it is handled correctly by other applications. I do not know what if any other embedded profiles also cause a crash.
The LuraTech JP2 plug-in reads all 8-bit RGB JP2 files that I have tried, but it ignores ALL color profiles.
My prime interest in XnView is as a color-managed viewer, and one of my most used formats is .JP2. I sincerely hope that a working combination is soon possible. At least, I hope that the offending ICC profiles can be selectively ignored without crashing.
I uploaded a sample file that causes a crash:
http://www.filedropper.com/lena-icc
Operating system is Windows XP SP3. XnView version is 1.97.6
Crash on JP2 read
phototweak
Re: Crash on JP2 read
Does the test file cause a crash for others?
- Forum Librarian
I don't have a crash. But then again, I can't tell which plug-in is used for JPEG2000 on my installation.xnview ([url=http://newsgroup.xnview.com/viewtopic.php?p=72623#p72623]1.96: (Possible bug) Jasper JP2k applying sRGB by default[/url]) wrote:Jasper plugin don't use ICC
phototweak
It appears to be the LuraTech library. If you temporarily move those files out of the plugin directory, what happens?
- Forum Librarian
When I remove the LuraTech DLLs...
- ldf.dll
- ldf_jpm.dll
- lwf.dll
- lwf_jp2.dll
Right, will be fixedphototweak wrote:Does the test file cause a crash for others?
Please try XnView 1.97.7
phototweak
I upgraded to the latest version of XnView (1.97.
today, and I still get a crash on my test file, while using Xjp2.dll.
could you try the 1.98 beta?
And which JPEG2000 plugin do you use?
phototweak
I am using Xjp2.dll plugin.
Using v1.98 beta 2 (unstable) it does not crash!
Is this beta safe to use? Could it corrupt files?
yes, final version will be soon available...phototweak wrote:Is this beta safe to use? Could it corrupt files?
