My system is Ubuntu Lucid 64 (using a 32 bits library for XnView ) and XnView MP is the beta (installed to-day morning).
When i ask e refresh after modifying jpg files, there's no refresh.
What i do :
- select some pictures shot vertically, they are displayed with an icon meaning "rotated according to exif orientation tag". This means these pictures would be displayed horizontally by a less elaborated software, that's why i want to modify the files, so that *any* jpg viewer, even old and/or stupid, would display them OK.
- use tools>JPEG lossless transformation > rotate based on exif value
- when the operation is over, the display is unchanged
- after refresh , again nothing changed
- if i go to an other folder and come back to the first one, the display is modified, the icon "rotated according to exif orientation tag" is not displayed any more.
MP 0.26 linux : refresh does not work in explorer mode
Dommage, l'était sympa cette planète ;-(
